Jagged Shadows in Iray
LearstangLearstang Posts: 46
edited January 2018 in The Commons
Does anyone else have problems with jagged edges on some of the shadows that get rendered in Iray? Some of the shadows look very realistic, but sometimes, and it seems somewhat random, there will be jagged edges, with angular artefacts between the shadowed area and the unshadowed area. This happens on figures I render. It doesn't seem to matter if it's a V4 figure, or a V8 figure. Any ideas on how to fix this? Thank you in advance!
Best Regards,
Jason A/K/A Learstang
Post edited by Learstang on
  • DustRiderDustRider Posts: 2,903
    With the image you posted it's hard to tell exactly what I'm looking at, so I'm guessing it's the arm pit?? My best guess is to try increasing render subdivisions of the figure by 1.
  • Yes, you are correct - it is the armpit. I should have posted a larger sample. I shall try your suggestion - thank you very much!
    Best Regards,
    Jason
    Hope it works!
  • I reset the render subdivisions and it works - thank you very much!
    Best Regards,
    Jason
    Glad it worked!!
