Adding to Cart…
forgot what i was workin on >.<
flu-zees zapped me >.<
hair combs, normals
softbody jiggle
is it time for valentines renders yet? or wait for after superbowl?
so when you lay out a line, add thickness, the original line remains?
adding thickness doesnt just puff it outwards, is puffing inwards as well?
twould be interesting to see the effect of ior through a plane, vs a cube, vs reversed normals
i better go sleepy, >.< work in the morning.
so many questions!! like the look of shadows falling on an object with subsurface scattering
I have no idea what you are talking about but it;s always pleasnt to guess.
It's like 3d Haiku.
I like the idea of shadows falling on subsurface scattering - the question being whether the shadows subsurfaces
Shadows aren't really a thing in themselves, they are the absence of light (at least compared to the "lit" areas). Usually not the total absence of light though, there will be environmental light giving color and definition into the shadowed areas.
You can add thickness with both positive and negative values to create a new surface either inside or outside the existing object. I'm not sure how this would work with just a line and no polys though - just try it and see!
attenuation is only on lights, nothing to do with shadows?
inverse squared, linear, etc up side down
If you want to get soft shadows with the default render engine, on the panel "effects" turn on the box "enable soft shadows" and encrease the size to a realy big value. Use raytrace shadows for smoother shadow surface. Don't use map shadows, they cause artifacts and pixelation.
ty!
what is shadow bias?
never understood it
My pleasure! You don't need to touch "bias", leave it as is. Otherwise, you may get a fan-like shadow.
tryin to figure out how to manually cut a 'tramp stamp' to fit,
cutting vertically down the middle wont work, seams are more like a coast line
the tc2 does have a tattoo option, but not for g3
song so pretty in french
dunno what language this. is, pretty
thought I'd have a go at modeling some LiS style clothes for my actors that will be in the Chariot and Space Pod..
started off real good and was just about to save when Carrara was hit by the big freeze....
The song is pretty cool. But when I see 3d people among the real ones I feel the uncanny valley.
song is from the Witcher 3 game. Geralt and Zoltan watching Priscilla's performance.
i'm in the middle of the Priscilla quest. 2nd try, messed up finding the villain 1st time.
having another go at a G8F preset, starting over.
wondering if it would make a difference to use ds utilities with my old pc with ds 4.8. can't hurt to try.
... well, that didn't help fix it
cant see the uderlying problem with g8f's nailbeds.
cant think of how to isolate 1 toe for corrective morph?
thinkin separate x,z,y morphs to move those misbehaving g8f nailbeds to where they belong.
heavy sigh, thinkin is time to write off g8f as the worstly made toenails ever
worse case of 3d tinia eva!
wondering why the image thumbnail doesnt show uploaded when creating a post.... but appears when you post....
someone been playing with forum code maybe!
never noticed before
mebbe is my method?
befor i hit post comment, i right click on the upl thumbnail, oprn to new tab. i manually edit the url to take out /thumnail part,
then insert image with twekaed url,
then hit post comment
how do yoos do it?
it's no longer showing the thumbnail for me in edit, when I attach a file it says it uploads but nothing shows... maybe a chrome thing.... yet the image thumbnail is posted when I post...
it's just blank!!
but they will show when I post...
i'm in chome, older version. my netbook winXP. havent tarted up the win10 netbook yet
8 cores on her way
Saturday, February 10 1:17 AM Package has left the carrier facility Redmond, WA US 12:37 AM
i;se scared they sent an openbox, or previously returned item.
my new rig should handle octane, i hope. win10 big wildcard software wise
tee hee
rootbeer rootme
cores
hope it don't get tossed around!
exciting stuff ... new toys
rootbeer
inconsistancies of content
the pose presets work on incantoo skeleton
pose presets do not work on the sy thingees
g8m fbms work dandy on g8m and all his toes
did they do the new toe thingies to him, or they skipped doing it to him
a mermaid tail character would solve the toenail problem, lol
Same problem Just started happening around 4:00 PM Daz time. It isn't your browser. I'm using Firefox.
I know that the guy doing a script to convert between different characters is also having issues with the nail beds.
there's nothing that makes sense for a morph to move verts in 1 software and not another.
the most likely suspect, thought something with the subdivision level, hypothetical verts.
doesn't seem to make a difference.
