Daz 4.5 - Base Lighting Set for Animations
freecomerfreecomer Posts: 0
IMHO the Daz default headlamp lighting is fine for setting up props and figures and getting an animation to a fairly good stage ... my challenge is then trying to find a decent base light set to light up the set and character and still render in 3Delight fairly quickly.
I've tried UberEnvironment2 with 3 point lighting, also various lightballs with distant lights, with varying results ...
So, I was wondering if anyone can recommend a favourite method or light set specifically for Daz to light up a set for animation for a simple amateur animation, say a simple walk on a runway using aniblocks or something similar ...
Apologies to purists and professionals, I do know that there are a million ways to light a set, depending on a million parameters, what I am seeking is just a nudge to what you might call a Daz 4.5 starter setup to give a little better result than the Daz default without making the render so slow as to not be worth the trouble ...
Any advice gratefully received ...
  • ReDaveReDave Posts: 815
    Personally for animations I'd use some ambient and one light. I was floored to see some of the results although shadows were hard to spot.
    UE2 is also a lot faster than it used to be (not to mention that being an animation, which will be compressed/blurred by youtube/whatever you can get away with much more graininess); try to cut down on the number of lights, normally if you have an environment it doesn't make loads of sense to add extra lights, unless they are specular only.
  • Scott LivingstonScott Livingston Posts: 4,348
    The things you tried with varying results...were the results unacceptable because the quality wasn't good enough, or because rendering was too slow? What are your system specs?
