why is the jacket does not fit well to this character v4.2?
are there's any shortcut to make any clothing fit properly on this characters without having to adjust many things? It seems to works fine on slim character, no need to have much of an effort for adjustment. But  how on characters with other shapes?
  • the sleeves is weird it pokes through the characters arm
  • SixDsSixDs Posts: 2,384
    I see from the screenshot that you are trying to fit Hongyu's Cowgirl 3 to Victoria 4. The Cowgirl 3 outfit comes in three versions: one for Victoria 5 (Genesis), one for Genesis 2 Female and a third for Genesis 3 Female. I can't tell which one you have, but for fitting, the first one V5\Genesis would probably hold the most promise for using V4*. There are utilities available in the store to facilitate cross-figure clothing use, but most are for using older clothing on newer figures. (*BTW, there is a version of the cowgirl outfit in the store specifically designed for V4\A4). Having said all of that, the first approach I would recommend trying is to add a smoothing modifier to the jacket and adding V4 as the collision object in the Parameters tab. You may need to tweak the smoothing and\or collision iterations to get the desired results.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,303
    and rightclick and choose transfer active morphs
