Adding to Cart…
Thank you BeeMKay for your reply. I do not have anywhere near the graphics card you have (Which you say took quite a while) on my 'gas powered' ancient iMac so will conclude that there is no way this will run on my machine.
Kind regards.
I finally have two simulation completed using Ecomaniac dynamic tree C But i cannot write thatthe result is so good : some leaves are ok but some others looks like artefact but not leaves .I stop the rendering when i see this poor results
Which settings did you use for quality?
someone pls show a selfmade clip
Richard : thanks
i have clicked on simulation collision good.tip icone and simulation quality medium icone and after i click simulation on the simulation windows
May be i don't understand really how to load preset or settings for simulation or something else i ignore about dforce
Which version of DS is this - Help>About daz Studio? The current is 4.10.0.123, dForce has been changing as updates are issued.
My version is 4,10,0,107
i had 4.10.0.123 before but My DAZStudio was crashing too often with this version so i have reinstalled the.107
If you are confident that is the source of my problem ,i will try again the ..123
Not confident, but it seems fairly likely since the leavse are draping (as far as I can tell) for most people in 4.10.0.123. You could always use the public beta if you want to hedge (so to say) your bets.
Thanks for your help, Richard
I still have the DAZStudio_4.10.0.123_Win64.exe
i will try during the next week
I have installed yesterday the version 4.10.0 123 and encounter the same problem with dynamic trees and DAZStudio still crashing too often again
I reintall the version .107 , more stable on my system and wait for another update
You probably are running out of memory. After you load the scene in the Render Settings set Optimization to Memory
Thanks nonesuch00 i will try
But i know i have 32 gigs Ram on my system
On your video card that memory although it should fall back to 32GB RAM to CPU OK unless your scene is really big and you run out on CPU RAM too.
