dForce Trees and Leaves - Brilliant!
2»
  • MusicplayerMusicplayer Posts: 515
    edited January 2018
    BeeMKay said:
    I have a 980Ti, and ran the simulation as a quick test yesterday at highest settings, and it took quite a while with the card working at full force.
    But I haven't tested on lower settings yet, and CPU.
    Thank you BeeMKay for your reply. I do not have anywhere near the graphics card you have (Which you say took quite a while) on my 'gas powered' ancient iMac so will conclude that there is no way this will run on my machine. sad
    Kind regards.
    smiley
    Post edited by Musicplayer on
  • MartialMartial Posts: 431
    I finally have two simulation completed using Ecomaniac dynamic tree C But i cannot write thatthe result is so good : some leaves are ok but some others looks like artefact but not leaves .I stop the rendering when i see this poor results
    806 x 806 - 970K
  • Which settings did you use for quality?
  • RuphussRuphuss Posts: 2,631
    someone pls show a selfmade clip
    edited January 2018
    Richard : thanks
    i have clicked on simulation collision good.tip icone and simulation quality medium icone and after i click simulation on the simulation windows
    May be i don't understand  really how to load preset or settings for simulation  or something else i ignore about dforce
    Post edited by Martial on
  • Which version of DS is this - Help>About daz Studio? The current is 4.10.0.123, dForce has been changing as updates are issued.
    edited January 2018
    My version is 4,10,0,107
    i had 4.10.0.123 before but My DAZStudio was crashing too often with this version so i have  reinstalled the.107
    If you are confident that is the source of my problem ,i will try again the ..123
  • Not confident, but it seems fairly likely since the leavse are draping (as far as I can tell) for most people in 4.10.0.123. You could always use the public beta if you want to hedge (so to say) your bets.
    Thanks for your help, Richard
    I still have the DAZStudio_4.10.0.123_Win64.exe
    i will try during the next week
    I have installed yesterday the version 4.10.0 123 and encounter the same problem with dynamic trees and DAZStudio still crashing  too often again
    I reintall the version .107 , more stable on my system and wait for another update
  • nonesuch00nonesuch00 Posts: 18,753
    You probably are running out of memory. After you load the scene in the Render Settings set Optimization to Memory
    Thanks nonesuch00 i will try
    But i know i have 32 gigs Ram on my system
    On your video card that memory although it should fall back to 32GB RAM to CPU OK unless your scene is really big and you run out on CPU RAM too.
