FWSA Khloe HD for Karyssa 8
Purchased the Karyssa 8 Pro bundle, all other products download and install but the FWSA Khloe HD for Karyssa 8 product fails to install using Install manager. Any one else having a simillar problem or how to fix it?
  • davegvdavegv Posts: 165
    I manual Download and manual install all my products and purchases and have NEVER had a problem
    Have you tried that?
  • nicsttnicstt Posts: 11,715
    Worked for me; try deleteing and redownloading the file.
    But try a manual install; my advice, put it in a custom library, as it is then easier to remove if you get the DIM install to work.
    If you were installing it in your main Studio installation folder, you would drop those 3 folders in the image in there: they should then appear in Studio.
    I suggest a different library, incase there is an issue.
    799 x 150 - 25K
  • liquidphantomliquidphantom Posts: 128
    edited January 2018
    I have all my content in a custom library on a seperate drive to the application, scenes on another drive. I got it working however but only by installing the package from within Studio itself.
    Post edited by liquidphantom on
