Interactive Tutorials
Supertigre
in New Users
I have been with DAZ for a few yearsnow and finally decided to take the leap to DAZ 4.1. I have a problem with the interactive tutorials. The insert on the screen (the big yellow one) fills the screen to the extent that the continue button is hidden. When I try to raise it up it raises, but as soon as I unclick it drops back down so I can't click the continue. How can this be fixed???
What rsolution is you display? It might work to right-click on the Task Bar, slect Task Bar Settings, and turn on Automatically Hide the Task Bar in Desktop Mode.
Do you have Studio set to full screen mode, or window mode? I get the same problem when I'm in Window mode, but if I set it to full screen, it works fine. In any case, even in Windows mode, you can make the lower bit appear if you increase the size of the window.
Moved reply from dupe thread to original thread.
