Is it possible to easily separate files from the content folder
I have a content folder with genesis 2, genesis 3 and genesis 8.
Is it there a script or something to separate the files from the content folder and place them in separate folders?
Not that I know of, though I'm not sure what you want - separate cntent directories for each figure?
Yes thats what I want.
I would like to delete Victoria 4 and Genesis 2 content completely.
If you installed via DIM or Connect you can select the items and uninstall them, then optionaly reinstall to a new path (bit of a fiddle with connect as it can use only one destination at a time).
