[Ask]exported files is broken
gstwin366gstwin366 Posts: 0
edited May 2013 in New Users
Hello.
I was Michael 4 export to fbx file.
Then, The exported files to look through the viewer, The instep is broken.
How to solve model broken?
I obtain the advice of your.
Post edited by gstwin366 on
    What viewer are you using? What version of DAZ Studio? Help > About DAZ Studio will give you the version number.
    Have you tried any of the other FBX export options?
    I will try this, and see if it happens in my version too.
    I tried this using FBX 2012, 2011 and 2010, and they all look like that for me. I tried 2006 Binary, but it is just the same. I am using the Quicktime Autodesk viewer. I tried Carrara 7.2, but it messed up the 2006 Binary file.
    I don't have any other programs to try it in, but it may work, it could be the viewer that is broken (unlikely) It would need to be reported as a bug in the Bug Tracker, I could do that for you, but it wont be fixed right away.
    816 x 540 - 135K
  • gstwin366gstwin366 Posts: 0
    Hi
    I think you have same problem me.
    I use Daz3D 4.5 version, and quicktime viewer, 3d max 2012.
    I tried by Daz3D 3 and 4. but had occurs the same problem.
    I can't find solution(how to solve).
    edited May 2013
    I will report this as a bug in the Mantis Bug Tracker, and I will post the number here.
    Have you tried Collada (DAE) instead, it might work better?
    EDIT:
    I have reported this as a bug on Mantis here : https://bugs.daz3d.com/view.php?id=50335
    Post edited by JimmyC_2009 on
    I tried export to dae file. but had occurs the same problem.
