Deciding to learn a modeler...is it better to invest time in Hexagon or Blender?
13
    BTW, the one feature I was thought was good enough to consider purchasing ZBrush for was the re-topology. Absolutely amazing the job it does. And I almost bought it just for that. But I couldn't bring myself to do it, when you consider the other apps out there (free) that do almost as good.
  • nicsttnicstt Posts: 11,715
    edited January 2018
    ebergerly said:
    When I tried Blender years ago it struck me that it was made by geeks - in a committee.
    I had to laugh when I read that. Probably the most accurate description of Blender, at least the early versions.
    Writing code is an entirely different skillset from designing user interfaces. And clearly Blender suffered from some great coders who couldn't design a UI. I mean, deciding to use a right mouse click to select stuff? Possibly the only application in the universe where an RMB is used. Although clearly not in the same league as ZBrush when it comes to UI's. In fact, after trying the trial version of ZBrush, my computer will no longer allow me to install any version of ZBrush ever again. It's strange. smiley
    Great idea.
    ... Because I am less likely to desect stuff, or select something else.
    Post edited by nicstt on
  • ebergerly said:
    Would have liked to hear that list that goes on and on because IMO after those things and navigation (which does make sense once you accept it was never made for mouse but for pen and tablet), I don't see much wrong with the UI.
    I tried ZBrush for the month (?) trial (or was it more than that...), and tried as hard as I could to learn it. I watched videos, and used it at least 3-4 times a week, and really wanted to buy it. Before going in I expected it was awesome, and I had cash in hand to buy it. But after the trial I got so fed up with trying to figure stuff out, and endless scrolling to find simple (and very commonly used) features that should have been front and center, that I totally gave up on it, vowing never to consider it. And I can't recall ever feeling that way about any software.
    Oh, and the polygonal modeller that's hidden in there somewhere? And the terminology they use is so different from other 3D apps, so when you're scrolling and scrolling you'll see what you want but not recognize it's what you want. My memory is very fuzzy on the details since I purged it from my brain, but I don't think anyone can objectively call that a well designed UI.
    And again, liking it doesn't mean it's well designed for the masses.
    Three words: User Interface Customization. What you may think is important may not be to someone else, so they gave you the ability to extensively modify what goes where, so you can put the stuff you use most often where it's easy to find.
    Two words: Got it.
    And that's what I do in Blender, using python. It's wonderful. But there is a point at which it's just not worth the hassle. And ZBrush is that point. If you can't even wrap your head around the basic way it does things, and the workflow, and what stuff means, spending more time trying to customize just isn't worth it to me. I'm sure others feel differently.
    And there's a point at which user customization becomes an excuse for poor UI design. It should be 10% customization, because the remaining 90% is well done, not the other way around.
    nicstt said:
    Great idea.
    Not sure if you're serious or kidding. No other software app on the planet uses RMB to select stuff. But in Blender's case it's okay with you?
  • bluejauntebluejaunte Posts: 2,265
    edited January 2018
    Using a scripting language to customise Blender UI is ok but dragging out some buttons in ZBrush isn't? Here's a slightly extreme example:
    Post edited by bluejaunte on
    I think that interface is a great example of an incomprehesible mess that looks like nothing I've ever used before.
  • kyoto kidkyoto kid Posts: 42,415
    ...I quit writing code many years ago due to severe burnout and really have little to no interest in going back to it again. This seems to be the route to go to really get Blender to work the way you want it to.
    Anyway, I suspect that a lot of ZBrush UI complaints are actually just a result of the extensive functionality. It's insane what they packed into that thing over the years. Naturally it's bursting at the seams but I almost feel like no amount of UI is going to make that more managable, at the end of the day it's just a complex tool that you have to learn slowly. Still miles ahead of Blender UI if you ask me, which is fragmented and ugly to boot. 2.8 will address this though.
    If it speeds the person's workflow, why does it matter if you personally find it comprehensible or not? That's the whole point of UI customization to me.
    That's probably because you've never used anything like it before? laugh
    edited January 2018
    Post edited by kyoto kid on
    edited January 2018
    Yeah, but a well designed UI needs to consider what its users are used to, don't you think? It needs to consider the other apps they've been using, and try to maintain a similar flow. Of course there are features that aren't found elsewhere, but still you can use a consistent philosphy in the design. And similar to Blender, which has tons of features, you need to take into consideration that most of your users won't use 90% of those features, so you don't need to put them front and center. You put the most used ones up front, and allow the other users who used the more complicated or professional stuff to do the customization. That's one of Blender's problems, though it's getting better.
    Honestly, you can justify ANY user interface. If it's poorly designed, then it's okay because it's customizable to fix the poor design. Or maybe it has tons of features, so that covers for the fact that there's all of those features you have to to sift thru even though few people actually use all of them.
    Anyway, discussing UI's will never result in agreement. It's 98% personal preference, so there's always a justification no matter what the design.
    Post edited by ebergerly on
    That's a legit complaint. The UI wasn't designed for what people tend to use ZBrush for now. It was designed for "2.5D painting," essentially painting on a 2D canvas with 3D depth information. Now that nobody uses ZBrush for that purpose anymore, the UI is completely wrong.
    edited January 2018
    Apparently they did as they made it for traditional sculpters. That's what I heard at least. And it did become the industry standard sclupting application, so I don't know. Was it just the amazing functionality that made people ignore the UI or did the UI maybe actually work at that level? In any case I struggled as well but overcame and realised that most of my troubles has nothing to do with UI but just the insanity of all the functionality.
  • TheKDTheKD Posts: 2,711
    During the sculpting process, I have everything minimized, just the the sculpt is on the screen. Everything needed, changing brush, changing brush size, navigations, is done with KB shortcuts. B for brush to see them all, narrow it down further by selecting the first letter of the brush you are needing. Space bar brings up the widget that lets you resize brush, change brush strenght etc. Shift to change over to smooth brush, and alt for all navigation. That screenshot above is by a person that likes to clicky more than use KB shortcuts it seems.
  • TheKD, I suspect it's someone that spends time using a Wacom drawing tablet instead of a mouse.
    Ah maybe. I use a wacom too now, but I started with mouse, so still used to having one hand on the KB, and one on the pen lol.
    For an $800 app (I think that's how much ZBrush costs...) the head of software should say this to one of their developers:
    "Hey, Fred, I want you to sit in a corner for the next month and design a few custom interfaces. Make one of them for new users who first try the ZBrush trial so we don't scare them to death and make them run screaming into the night. Just hide all that ridiculous 2.5D stuff they won't need, and all the detail stuff they won't need for 3 years when they become professionals. And make the polygonal modeller front and center and easy to understand. Real simple. Got it?"
    That's all. Maybe ask the user what apps he's familiar with, and design some interfaces that are kinda similar. They can select a Blender-style interface, or Maya, or whatever. If it's so easy for users to do, it should be super easy for the developers. Especially if they're gonna charge $800.
  • Have you tried Sculptris, ebergerly? It is in a lot of ways more intuitive and focused on just sculpting/painting.
    ebergerly said:
    nicstt said:
    Great idea.
    indeed, because it is the only app, it's a deliberate action. When  I first learnt Blender it was a curious thing, but 3D software were perculiar beasts... And still are.
    That $800 buys you a perpetual license for the software, unlike with the cost of some other applications these days. Also, that UI example above is the actual UI used by one of the model makers for Square Enix and was used to make at least one of the characters in the most recent Final Fantasy game. There are plenty of other options out there if you look. Anyway, I think we've gone far enough off topic for this thread.
  • ghastlycomicghastlycomic Posts: 2,531
    Hexagon is much easier to use and functions more or less like every other vertex modeler. Blender is a beast unto itself. It's an old in-house DOS based vertex modeler from the days when mice had one button that has been kluged together over years but never developed a proper GUI. I've tried Blender and it's the only 3D software I've ever used that failed the 15 minute UI test. Even moving the camera is completely different from the way every other program moves the camera. Plus when all I need is a vertex modeler Blender is a bit of a hog since the modeling part of it can't be separated from the rest of the software that I don't need.
    And if the rumors of a modernized Hexagon coming down the pipe turn out to be true then that's all the more reason to learn the software. Plus like I said, Hexagon is functionally similar to most other 3D software in how it works so learning another program after learning Hexagon won't be that difficult. One of the big complaints I've often heard from Blender users particularly students who self taught on Blender as amateurs but now have to learn Maya for school is since their UI is so completely different from the rest of the industry when you've learned to do things the Blender way it makes it very difficult to learn other 3D programs.
    ...good points.
  • rsharp_3144816rsharp_3144816 Posts: 99
    edited January 2018
    Would love to try Hexagon, but alas am using an iMac Pro now with macOS 10.13.  I've been recently evaluating quite a number of packages.  For modeling, I still use Strata Design Studio 3D.  UI not the best, but along with modeling, you have nice render options.  Can also output various "pieces" (e.g. specular highlights only) to separate Photoshop layers.
    Recently, tried demos of ZBrush, Lightwave3D and Cinema4D.  Tempted to try Modo, but that, along with Cinema4D are way beyond my budget.  While you can buy it outright, you're ultimately penalized if you don't then sign up for their yearly maintenance plans (i.e. the cost of upgrades increase over time).
    Also tried Blender for a second time, but just hated it.  e.g. I made a cube and saw the familiar three handles for positining.  Great!  Then clicked 'Rotate', and no handles.  But as I moved the mouse around, rotation occurred.  Same for scale.  Only positioning seems to give you the familiar three handles.  These types of inconsitencies personally drive me nuts.
    Ultimately, whatever I move to will need to run on 64-bit.  Many of the above do.  But Strata does not.  And support not getting back to me, so not a good sign.
    Post edited by rsharp_3144816 on
  • InkuboInkubo Posts: 745
    edited January 2018
    The handles are there, but just like in DAZ and other software, you get to choose which combination of handles will appear. Here are the handles:
    Blender's transform widget handles
    And here is the UI element you click on to select which ones appear:
    Manipulator visibility toolbar buttons
    715 x 298 - 100K
    215 x 38 - 5K
    Post edited by Inkubo on
    Also you can shift select to get all 3 types of handles at the same time....
  • nekyonekyo Posts: 57
    edited January 2018
    You really do just need to try different programs yourself - enough to get used to how they work, and see if you like it.
    I was forced to use 3DS Max in school, then at various companies I worked at - despite all my hours put into it, I could never get used to it. I tried Blender for fun and something about it just clicked with me - I have never looked back.
    If you try and try and it's just not working, try something else! It's more important to make things, have fun, and gain experience any way you can.
    Post edited by nekyo on
    edited January 2018
    ...yeah for me it turned out to be Hexagon, though the one downside was the terrible instability.  Modo was next that i really liked, but that began to become too expensive an option, particularly as it gravitated from primarily being modelling software to a full feature programme like 3DS.
    I just couldn't get into modo.  I could get past the UI, but it has horrible bugs.   One was that I clearly had a single object selected, subdivided it, and it subdivided a different object.   When painting one object, it automatically applied that texture to most of the objects in the scene.  I couldn't figure out what it was doing.
    As with most software trials, I put them away for a bit and come back in a few days.   In all cases though, I continued to have bad experiences in not only modo, but Blender.  They could be bugs, or they could be that their workflows are just not for me.    Complete opposite experiences have been Cinema4D.  Alas, the most expensive option though if I pursue it.
    Back to modo... I was really hoping it would have worked out.  While expensive (up-front and yearly maintenance), it is 55% the cost of Cinema4D Studio.  While there are cheaper versions (e.g. C4D Broadcast), they don't have key features.   But, one also has to look at productivity (and ultimately throughput) of the software.  So even at a higher cost, if C4D allows me to crank out output at double-the-rate over modo, then it would pay for itself.
