ManifestFiles Folder
I'm setting up DAZ Studio with a fresh install of everything, software and content. I installed the program on my SSD (C: drive) and installed the DIM on the HDD (E: drive). I've set up everything in the settings of both programs to install all my content onto the HDD, including all the downloaded DIM files and DAZ Connect files. This will let me save as much room as possible on the SSD. However, there is still one folder I'm not sure how to move if it even can be moved. That is the ManifestFiles folder and everything in it. It's not very big but it could probably add up after a while. Is there a setting somewhere to change it's location or does it have to be on the same drive as DS?
  • You have to edit the .ini file - C:\Users\YOU\AppData\Roaming\DAZ 3D\InstallManager\UserAccounts\Account.ini, you need to enter the desired path (using / to separate fodlers) for OverrideManifestDir:
    OverrideManifestDir=F:/DIM/Manifests
  • QuasarQuasar Posts: 679
    Thank you for your help Richard!
