Lips Morph
Has anyone come across a lips morph package?  For Gen3.  Couldn't find any that puckers, or blows a kiss, or blows smoke from a cigarette.  Lips are generally static, sure you could move bottom and upper lips but none I've found are pronounced enough to bunch together like a pucker.  Any suggestion?
Thanks in advance for any help.
  • RacerDCRacerDC Posts: 50
    Thanks Zombie, I have both those products.  Still they dont produce the pucker effect.  I might have to rely on post production via photoshop usinbg the warp tool.
    There are two lip pucker pose controls.
  • zombietaggerungzombietaggerung Posts: 3,879
    edited January 2018
    There should be two lip morphs for puckering; Lips Pucker and Lips Pucker Wide. If the default isn't enough, you can always click on the little gear icon by the morph name and turn off the limits.
    edited to add images
    1280 x 800 - 147K
    1280 x 800 - 143K
    1280 x 800 - 141K
    1280 x 800 - 140K
    Post edited by zombietaggerung on
    Thank you both, I'll give it a try again.
  • nonesuch00nonesuch00 Posts: 18,830
    I think the lip pucker morphs are actually included in the G3M & G3F Expressions packages not the Head Shape packages.
  • I think the lip pucker morphs are actually included in the G3M & G3F Expressions packages not the Head Shape packages.
    They're part of the base. "Expressions" are just control dials of base stuff.
  • Victor_BVictor_B Posts: 392
    Base expressions can do that plus there are many pucker faces in expression packs.
    Expressions for Genesis 3 Female(s)
