complaint/suggestion about the Product Library - SOLVED - was ff quirk
Mistara
when i click on an item it sends me back to square 1.
can they make it so it stays on the square i'm on when i click on something?
48 squares to go :roll:
and when i filter and then click on something, the filter is removed.
Post edited by Mistara on
You know search and keywords work don't you?
I had the same problem with my Firefox initially but it was fixed for me. Maybe the script is cached? Do you get the same thing after you reload with F5?
F5 removes the filter.
trying to stay filtered on genesis stuff. i wanted to install the 4.5 with fresh d/ls.
it's a browser quirk? thanks. i'll give it a try with safari.
Yep, it was Firefox. THANKS.
filtering on genesis doesn't show all my genesis loot. example: Aiko5 didn't show.
