GoZ Import Issue?
Seems i'm having all kinds of issues today and this is my 2nd discussion.
I'm trying to create a morph for an item of clothing I recently purchased, but its not behaving nicely. I use GoZ to send my figure with the clothing parented to it, edit the clothing in Zbrush, then click GoZ to send it back. On all other things i've done it works fine, however, this time for the first time I get a message that the typology has changed and it wants to know if I want to add as a new object. I don't even have to touch the object in Zbrush, just immediately hit GoZ and it gives the message. I even exported the clothing from Zbrush to an OBJ, then was able to load the OBJ correctly with Morph Loader Pro just fine.
GoZ is much easier, just wondering if anyone knows what may be happening. The clothing is Body Chains by Sshodan.
thanks in advance
p.s. I have closed Zbrush and Daz3d and restarted both apps. I've started with a saved Scene to Zbrush as well as a New scene and fresh figure and clothes. Same result every time.
Some items seem to be made in a way that isn't compatible with how GoZ for DAZ Studio works, so exporting to obj is probably the best workaround available.
Thanks Daywalker,
sounds like I need to brush up on my Morph Loader Pro understanding and not rely so much on GoZ. Since I posted this I've read more forum discussions which seem to show it has some quirks that i'm just now running into.
