Genesis Riding Habit Boots Weird Morphs
luci45
The boots on the Genesis Riding Habit fit OK on basic male and female. Using V5, S5, Julie and some others cause this distortion. Is there a way to fix it? The feet are in the default pose.
After the boots are conformed, select them and change their scaling to 100% in parameters. I'm not sure why it's happening, but when I check it that fixes it.
Thanks, but that didn't help.
Redownload and reinstall?
I Redownloaded and reinstalled. Same problem still. Attached is with boots at 100% on V5 this time.
As long as the genesis figure is not larger or smaller than 100% the boots are fine.
Am using DS4.5.1.56. Am I the only one have this problem?
Here's a patch, for you and anyone else who has the issue: https://dl.dropboxusercontent.com/u/92155353/DressageBootPatch.zip
Somehow the "inherit parent scale" button got unchecked on the shins. Still don't know how it happened or why neither I nor testing caught it, but that should fix it. You'll need to delete the old files if you've moved them out of the default /people/genesis/clothing/sicklemar/riding habit directory.
