Aged for V4/M4 - Got A BIG problem(s) :(
Strixowl
Running DS Pro 4.5.1.56 64bit on Windows 7 64bit
Purchased "Aged for V4/M4" yesterday and am at the end of my frustration ropes :cheese:
First Issue
The store page says, under "What's Included and Features" tab
4 Character Presets for Victoria 4.2
Full Aged INJ/REM
Aged Hands INJ/REM
Aged Head INJ/REM
DAZ Studio Only MAT Options Include:
FUll Aged
Full Aged MAP Only
Partial MAT Displacement Only 0
Partial MAT Displacement Only 25
Partial MAT Displacement Only 50
Partial MAT Displacement Only 75
Partial MAT Displacement Only 100
The installer, installs under My Library/People\Victoria 4\Aged for V4\Poses - Just 1 INJ preset called "V4 Aged". When clicked it does what I expected for the Head (nothing else) but there is no remove preset or or any of the following listed above "Full Aged INJ/REM,Aged Hands INJ/REM,Aged Head INJ/REM. I've download and installed a number of times with the same result :(
Where are these presets? There not listed in the file list either.
Second Issue :(
In the tutorial that comes with the product (see below) number 3 it says "Inject the "INJ Aged for V4" in the "\Libraries\Pose\DAZ's Victoria 4\Morph Injections" folder". Wonderful, but where is this file suppose to come from? I don't find it in Morphs ++, any other V4 morphs or the Product File list and the product page doesn't list any other needed morphs. Very confused. :P
To use Aged for V4:
1- Load V4
2- Inject the V4 Morphs++ Product into the figure
3- Inject the "INJ Aged for V4" in the "\Libraries\Pose\DAZ's Victoria 4\Morph Injections" folder
4- Load the DS preset "V4 Aged.dsb" in the "\Content\People\Victoria 4\Aged for V4\Poses" folder
5- Apply skins, clothing, and other items as normal.
Thanks for any help you can give :)
First, I question if you have all of the files. For DS 4.5 there are three files for V4 and three for for M4
If you go to the Product Library, you'll have all of them if you download the six flagged with the green DIM label.
Edit: The Powerloaders are optional, but they are convenient for pre-injecting morph packs when loading M4/V4.
Under the Content Library Tab you should have this
Daz Studio Formats>My Library>People>Victoria 4>Aged for V4 in it you should have Characters, Materials and Poses
Also under the Content Library Tab you should have
Poser Formats>My Library>Pose>DAZ's Victoria 4>Morph Injections It should hold INJ Aged for V4.pz2 and a Folder
Aged for V4 that holds these AgedHands.pz2 and AgedHead.pz2
If not you do not have the full bundle installed. The M4 should be about the Same. The Diff is the Figure Names.
From memory you need to run the updater script that comes with gen4 models to configure the proper channels, is called 'update Michael 4 Base' and 'update Victoria 4 Base' in my install folder :)
Hey everybody thank you so much for your help. I didn't have all the files. With all the file types/names listed I got confused as to what I needed and what I didn't. :)
