Daz Problem with Partial Renders
I keep getting renders that start out with a portion of the image as being partially done and it never fills in. You can see this in the attached image. I end up reducing the size of the render but I hate doing that, I have minimum size requirements when creating images for commercial use.
  • 3Delight or Iray?
  • You're exceeding some limit on something. Time, number of passes/iterations, or something like a memory or buffer limit.
    Are you calling a post-process script in the render settings? Maybe that's firing too soon and truncating the render?
    Are you using Scripted 3Delight and there's an issue with the script when images get that big?
  • mwokeemwokee Posts: 1,275
    Iray. I pretty much use the defaults because I don't know Daz that well. I just set the size fairly large for pixels such as 4k x 3k.
