Velvety Goodness! 40% off for purchasers of Sheer Greatness! [Commercial]
DraagonStormDraagonStorm Posts: 748
Velvety Goodness! Now available in my My DAZ Store
40% off for those who have or purchase Sheer Greatness!
A new innovative shader for DS4.5 with easy to use interfaces so that you can create or enhance any surface in your DS library. Velvety Goodness will give your textures a beatiful velvet look, either over existing textures, or use the scripts that come with this set to create your own. There is a shader to apply velvet to any current texture, and 5 other scripts, where by what you select, will apply different looks and designs of velvet.
There are 5 different designs to choose from, where designs are applied. And depending on what type of velvet, you will be given different color and other setting choices.
A very special thing with this shader, is that each setting that has an image, had it's own tiler setting. With this you will be able to use texture sets that use transmaps to change the 'cut' of the object (such as a lot of MFD texture sets), but still tile a design, without the transmap also tiling. Or use a tiled image in displacement at Horizontal and Vertical 10 like a special weave, and then use a Normal map with a design tiled at Horizontal and Vertical 3. You have more control of tiling with these added settings.
Post edited by DraagonStorm on
  • DraagonStormDraagonStorm Posts: 748
    You will be able to choose Colors and Designs from easy to use interfaces.
    1300 x 650 - 570K
    1300 x 650 - 645K
    1300 x 650 - 484K
    1300 x 650 - 553K
    1300 x 650 - 316K
  • SedorSedor Posts: 1,764
    Currently I am playing around with it, love that we are able to tile every setting that is image based - that's really great!
    No first renders?
    Then I post my first one, applied Velvet Goodness at her Bra and Panty
    1125 x 1500 - 428K
  • Joe.CotterJoe.Cotter Posts: 3,361
    Very nice, both the shader and your image Sedor :)
  • GranvilleGranville Posts: 697
    Thanks DragonStorm. I love your shaders.
    Very nice Sedor...
    I'm looking forward to seeing what you all do with my shader.
    Thanks!!
    Here's another one I've done using your shaders (at the boots, the top and pant):
    1125 x 1500 - 523K
