Recent issue with G8M Quads- SOlved
Serene Night
I've been having issues recently with G8M quad muscles dialing themselves inappropriately. It seems a recent occurance because I would've remembered such deformities. As you can see it is dialing the muscles in at -800 and sometimes in at 1100 and such when I apply poses where the legs are bent.
I'm not sure what is causing it...
Is there something I can check to see if it is being triggered? I have shown hidden properties and there I see the quad group fired up at the ugodly -1100 degree.
I can remove it... Not a problem and the pose looks fine. But where would I got to begin to troubleshoot this?
Perhaps the Respect Limits switcxh on the morph or one of its controllers has been cleared? You can check that, and what the limits are, in the Parameter Settings dialogue reached by clicking the gear on the slider.
That proved to be the case. I changed them both to respect limits. Normally I don't have a problem but for some reason the quads kind of went out of control. Glad it was an easy solution.
Thanks,
Wyn
