Daz3D interface won't display.
When I launch the program, the splash screen shows up and the application proceeds as usual up to the point it's building the interface and then nothing appears (with the exception of an icon in the taskbar indicating the application is running). There are no windows or menus displayed at all so there aren't any setting I can access to make changes in the program configuration.
I uninstalled 4.9 and reinstalled it using the install manager. When I launched Daz3D again, I got the same problem but this time it displayed a postgresql error. I uninstalled that component and reinstalled it. No change. I installed v4.10. No change. I've updated graphics drivers. I've restarted the system several times.
It's just a laptop that I'm using, but the application has been running fine up until today. First the keyboard shortcuts (Ctrl-Z, etc) quit working so I shut the program down, went through the steps I explained above and now nothing works at all.
Any help would be appreciated.
Thanks in advance.
  • __ Posts: 16
    After trying several system changes, I found that switching the laptop display to "tablet mode" allows the system to show the program on the screen,. However, unless I use that mode now, the program still won't display.
    I wouldn't call the problem solved as this "tablet mode" is not what I would prefer to use for a system I'm performing work with. It's a very gimicky setting. At least this work around seems to be holding and I can get some work done for the time being.
