Has anyone tried using Marieah's 1-click products on Genesis
Dkgoose
I am wondering if it is possible to use the 1-Click products with Genesis using the V4/M4 UV'S, I'm reinstalling everything and only installing what I'll be able to use with Genesis for the most part. I'll still have the base figures and morphs installed for GenX so I can use them if I need to though.
I've just had a quick play with several of the sets and there's no issue I can see, stuff works as expected (provided you have the right UV selected).
You should also be able to take the source files and slide them straight onto any Genesis(or whatever) with LIE, One Click just automates the process for a particular UV.
ok cool, thanks for the reply, I've been holding off redownloading, I'll download them now.
