Dforce or VWD cloth. Any advice?
2»
  • Sorel said:
    Isn't there a walking animation being done in the official dforce video?
    For sure.
  • thd777thd777 Posts: 945
    edited December 2017
    @wolf359  What problems do you have with setting up a walk? I have done several without issues. Here is a quick and dirty example using G8F and the bardot dress. Set up using aniblocks, simulated in ~8 min and rendered with Iray in 12 min. The default settings need a few tweaks, I think they are optimized for still renders. I just reduced the friction, lowered bend stiffness and added some velocity smoothing. I messed up the animation of the hands, thumb passes through the thigh at some points causing some distortion. But that's my fault not dFrorce.
    Ciao
    TD
    Update: Fixed the hand/skirt issues and added some hair. Animation is still very basic, but the walk and dFrorce work fine.
    Post edited by thd777 on
  • ToobisToobis Posts: 993
    can you use them both in unison? just had to ask.
  • grinch2901grinch2901 Posts: 1,247
    Yes, for a short time when DAZ Studio 4.10 came out it killed the VWD bridge because OBJ export got dorked up. In the latest official release of Studio it's fixed and the bridge works again. So the can co-exist and I use both, though for now more VWD than dForce.
    K thankyou.
