DAZ4.5 error log file???
broncomechbroncomech Posts: 0
I have screwed something up in my install and now I get an error message every time I load something in DAZ3D
Error reads " Duplicate formulas found in files. Make sure the content is properly installed. See the log file for more details."
Where is the log file supposed to be located??
  • fixmypcmikefixmypcmike Posts: 19,696
    Inside DS, Help > Troubleshooting > View Log File
    It looks like you have outdated versions of some of your content -- specifically, I believe it's the Genesis Evolution Expressions, Genesis Evolution Head Morphs, and V4 and M4 Shapes for Genesis that have this problem. The locations of the Evolution morphs changed after the first update, so you need to uninstall the old version before installing the new one.
  • broncomechbroncomech Posts: 0
    Thanks for the directions.
    I uninstalled , downloaded & re installed the one item I have that you listed (Genesis Evolution Head Morphs) and still get the same error.
    Checked the log file ans it looks like possibly some non DAZ content is causing issues, here is a small portion of the entry in the log file created after re installing the evolution head morphs.
    WARNING: fileinput\dzassetdaz.cpp(4962): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/Richard McCormick/!Head Enhancements/Head-Brows-OuterUpBulge/Head-Brows-OuterUpBulge.dsf#Head-Brows-OuterUpBulge?value in file : /data/DAZ 3D/Genesis/Base/Morphs/Richard McCormick/!Head Enhancements/Head-Brows-OuterUpBulge/Head-Brows-OuterUpBulge.dsf
    WARNING: fileinput\dzassetdaz.cpp(4904): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Sasquatch/Raw_Sasquatch.dsf
    WARNING: fileinput\dzassetdaz.cpp(5136): Duplicate formula found linking xOrigin & Value in /data/DAZ 3D/Genesis/Base/Morphs/HFS Shapes/HFS_Shapes_Head01.dsf.
    Do you have Freak 5? That's needed to get the Sasquatch morph to look as intended. Not sure if RAMWolff's and HFS's morphs have been updated. Are things working in spite of the messages? You could try Richard Haseltine's duplicate ID fix script: http://rhaseltine.ovbi.org/Fix_Duplicate_IDs.zip
    No Freak 5 here.... Yet
    So far everything I have attempted has loaded shortly after acknowledging the error message and the only figures that seem to be effected are Genesis based.
    Attempted to run fix duplicate ID and get this error
    "Executing DAZ Script file: C:/Users/Public/Documents/My DAZ 3D Library/People/Genesis/Fix Duplicate IDs.dsa
    DEBUG: Script starting
    WARNING: Script Error: Line 62
    WARNING: SyntaxError: Unable to parse JSON string
    WARNING: Stack Trace:
    ()@:62
    Error in script execution"
    For some reason the Genesis does not show up in C:\Users\Public\Documents\My DAZ 3D Library\People\Genesis when attempting to run the script.
