Help? Send In The Clones Not Working
JasmineSkunkJasmineSkunk Posts: 1,906
edited December 2017 in The Commons
I have Send In The Clones Pro... which I no longer see in the store.
I let the DIM install it for me, but when I try to open it, I get an error that says to check the log. I have no idea how to check the log.
Post edited by JasmineSkunk on
  • OK... Found the log... But no idea what it means.
    Please help?
    Log file:
    2017-12-17 22:32:32.236 WARNING: Stack Trace:
        <anonymous>()@G:/DAZ Library/Scripts/Utilities/SendInTheClones DS4 PRO/SITC DS4 PRO.dse:513
    2017-12-17 22:32:32.238 Error in script execution: G:/DAZ Library/Scripts/Utilities/SendInTheClones DS4 PRO/SITC DS4 PRO.dse
    2017-12-17 22:32:50.839 Loading script: G:/DAZ Library/Scripts/Utilities/SendInTheClones DS4 PRO/SITC DS4 PRO.dse
    2017-12-17 22:32:50.949 WARNING: Script Error: Line 513
    2017-12-17 22:32:50.949 WARNING: Error: Function.prototype.connect: ambiguous connect to DzTabWidget::currentChanged(); candidates are
        currentChanged(int)
        currentChanged(DzWidget*)
    Use e.g. object['currentChanged(DzWidget*)'].connect() to connect to a particular overload
    2017-12-17 22:32:50.949 WARNING: Stack Trace:
    2017-12-17 22:32:50.958 Error in script execution: G:/DAZ Library/Scripts/Utilities/SendInTheClones DS4 PRO/SITC DS4 PRO.dse
    2017-12-17 22:33:16.614 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-12-17 22:33:21.047 *** Scene Cleared ***
    2017-12-17 22:33:23.552 Loading script: G:/DAZ Library/Scripts/Utilities/SendInTheClones DS4 PRO/SITC DS4 PRO.dse
    2017-12-17 22:33:23.661 WARNING: Script Error: Line 513
    2017-12-17 22:33:23.661 WARNING: Error: Function.prototype.connect: ambiguous connect to DzTabWidget::currentChanged(); candidates are
        currentChanged(int)
    2017-12-17 22:33:23.668 WARNING: Stack Trace:
    2017-12-17 22:33:23.670 Error in script execution: G:/DAZ Library/Scripts/Utilities/SendInTheClones DS4 PRO/SITC DS4 PRO.dse
    2017-12-17 22:35:34.941 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-12-17 22:38:22.131 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-12-17 22:41:21.475 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
  • JasmineSkunkJasmineSkunk Posts: 1,906
    OK...Now, I've made it worse...Somehow.
    I let the DIM uninstall it and downloaded the .exe file and installed it that way... Still didn't work.
    nm, I guess... I sent in a ticket. smiley
    662 x 363 - 41K
  • BeeMKayBeeMKay Posts: 7,019
    It's possible that compatibility was broken when they got to 4.10. But CS will know.
  • Well, I got a response from support a bit ago... but, not really. Here's what they said:
    Thank you for contacting Daz3D Tech Support.
    We strive to answer all email support requests as soon as possible.
    We do not operate as a 24 hour help center. Our hours of operation are Monday - Friday, 9am-5pm, Mountain Standard Time. Please note, it can take up to 1-2 business days for a response, and up to 5 business days for a resolution. There are rare cases that take longer to resolve, should we need to conduct additional testing or other departments to step in.
    In the meantime, please feel free to take a look at the commonly asked questions and links below. If you should find the solution, please make sure to let us know and solve your ticket.
    We will get back to you shortly!
    Thank you
    Daz3D Team
    COMMONLY ASKED QUESTIONS
    - Having a hard time locating your serial number(s)?
    https://helpdaz.zendesk.com/hc/en-us/articles/207531733
    - Install Manager cannot find a required path...
    https://helpdaz.zendesk.com/hc/en-us/articles/208696966
    - Need more information on setting up the Install Manager?
    https://helpdaz.zendesk.com/hc/en-us/articles/207530523-How-to-install-the-Install-Manager-and-Daz-Studio
    - Having issues installing Bryce 7 Pro?
    https://helpdaz.zendesk.com/hc/en-us/articles/207528793
    - "Daz Studio cannot establish a valid PostgreSQL connection" error.
    https://helpdaz.zendesk.com/hc/en-us/articles/207812393
    - Cannot Sign Into Daz Connect and I Get a Login Failure in Daz Studio 4.9
    https://helpdaz.zendesk.com/hc/en-us/articles/207496406
    - Daz Studio Crashed
    https://helpdaz.zendesk.com/entries/25537469-Bug-Reporting
    So... the only one that looked like it might apply was the PostgreSQL thing, so I installed it, but no go. Same log file error. Guess I'm just waiting... frown
  • That's an auto reply, just letting you know the ticket has been assigned and suggesting links to frequent answers. it isn't the real, human-authored respoonse.
    clones the same as instancing in DS?
    Thanks, Richard. I kinda figured that's what it was.. wink
    DS does instancing? I'm not sure if it's the same thing. SITC Pro is supposed to clone figures as well as props... Well, up to whatever your system can handle. And it does it in one sweet click! smiley
  • scorpioscorpio Posts: 8,533
    Yes DS does instancing now.
    I think instances are different to clones with an instance you can't alter the pose or colours or textures or anything without altering the original, but you can instance figures or anything.
    Cool! smiley
    I did not know that!
  • HavosHavos Posts: 5,597
    Note that Send In the Clones is a pretty old product. This product: https://www.daz3d.com/instances-plus-for-daz-studio is a much more up to date script for creating and arranging instances, and is a lot better IMHO, albeit I can not be certain as I do not own the older version.
    Please note that the PA of this product (Draagonstorm) passed away last year, so any support you get will be from DAZ's own support staff only.
  • kyoto kidkyoto kid Posts: 41,943
    ....so the original plugin is broken if you move to 4.10?
     I am very sad to learn this. broken heart
    I don't know if that's it or not, KK. No word yet.
    Oh, I am so saddened now...
    Draagonstorm, Dimension3D, Jaderail...
    This is too much sad to learn about all at once. broken heart
    ...also Wancow.
    I feel indebted to him for lighting a fire under me to push the limits of morphing and character development. My Icon is a result of that.
    Post edited by kyoto kid on
  • IvyIvy Posts: 7,165
    @ JasmineSkunk I can confirm  SITC pro does not work with DUF files. if you load  the character  you want to load as a Victoria 4 or M4 ,  PZ, CR2 or .DAZ in those file format  the SITC will load those characters sets in daz 4,9 &4.10. But if you try genesis 2, 3 or g8  it will give you DUF is not reconized files formats and & you will get the code errors that you are. I just tried it with my copy & thats what I got too.
    you can try loading a V4 or M4 and see if you have the same issue.  But like Havos mentioned its a pretty old set it was made for daz 3. SITC only accepts those old file formats PZ,PZ3,CR2 &DAZ.  thats the best information I can give you why it won't work.
    ...so will it still work with props?
