Rendering in full HD and some advice needed.
Hi.
Are there any Render settings that will help produce a great, Full HD render?
As for advice... I would like to start making money from my renders (commissions etc), but I have no idea where to start. So some advice would be really great.
Thanks ^^
  • TheKDTheKD Posts: 2,711
    Not really. A bad render is probably going to look worse in HD size. Need to have good lighting, composition, color harmony etc etc.
    To save time, I usually get the lighting set up where I need it, then make sure it renders bright, and darken if needed in post work(renders that are really lit up render faster). I also usually try to render larger than I need it and scale down to size. Also under filter, if you use lancoz or mitchell set to 1.2 or more it gives it a nice extra sharpness look. I always find guassian filter to be too soft.
  • What, beyond image size (which can be set in the General group in Render Settings' Editor tab), is needed? Remember that DS renders don't have a PPI setting, they are just a certain number of pixels wide and tall, so if you need to supply the images with a set PPI you do that in an image editor (with Resample off so the pixel count stays the same).
