Can't use dforce weight mapping?
in The Commons
I've followed several different tutorials to the letter, but when I try to paint on my object with the node weight map brush, nothing happens. It won't paint. Not sure if I've missed an essential step somewhere or not, or if something is wrong? Has anyone else had this problem or know a solution? I'm trying to create a clothesline, and it's pretty impossible without being able to set points that don't morph in dforce! Thanks!
I'm having the same issue. I've tried to fix it, I want to use dforce weight map like in the tutorial but can never get it to paint.
You need to keep the Alt-Key pressed for the brush to substract.
Thank you! I knew I was missing something!
