mcjInterPose - Daz Studio script - Mix 2 poses using a slider - animatable, multi-figure
mCasualmCasual Posts: 4,607
edited December 2017 in Freebies
maybe someday ( in 2018 ) there will be another version or as as a plugin
The Script >>> https://sites.google.com/site/mcasualsdazscripts8/mcjinterpose
animated demonstration here : https://mcasual.deviantart.com/art/later-today-mcjInterPose-for-Daz-Studio-719084669
The first time you run this script, a new node named 'PoseMix' will be created.
You should then exit this script and animate the 'PoseMix' property of the 'PoseMix' node.
Pose your figure(s) one way at frame 1801 and pose your figure(s) a different way at frame 1802
Select the root node of your figure(s) and run the script again
Select the range of frames to be processed
Press the DoIt button
The script will go frame by frame. The value of the 'PoseMix' slider
will control the the mix between the pose at frame 1801 and at frame 1802.
Note that you can also specify other frame numbers than 1801 1802.
Post edited by mCasual on
