Extendable/Stretchy Limbs
caine collincaine collin Posts: 0
I was wondering if there was a way to make Stretchy/extendable limbs (for Genesis) somewhat like Mr Fantastic, Stretch Armstrong, etc.
  • BlackFeather1973BlackFeather1973 Posts: 739
    Scaling will go a long way (turn on 'Show Hidden Properties' to show X, Y and Z scaling in the parameters tab).
    edited April 2013
    While you can scale limbs, the problem isn't with the stretching, it's with the flexibility. The figure will still be limited in terms of movement by the bones in the arms, so you can't do 'toon style' flexible arms if that's your aim. Not without altering the rig at least. For still renders however, you might be able to use D-Forms to achieve the results you want.
    Post edited by Herald of Fire on
  • caine collincaine collin Posts: 0
    Awesome, thanks a bunch, hadn't even thought to look for a "show hidden properties".
