Script for camera position
rbel_295e7c1d4crbel_295e7c1d4c Posts: 99
Is it possible to use a script that would allow me to set/reset parameter x,y,z translate and rotate slider settings?
  • Richard HaseltineRichard Haseltine Posts: 109,650
    Doesn't File>Save as>Camera Preset do that?
  • rbel_295e7c1d4crbel_295e7c1d4c Posts: 99
    It does indeed - many thanks. I should use presets more often instead of looking for complicated ways of doing things.
  • ReDaveReDave Posts: 815
    The "complicated" method (actually not that much) is to click on the Parameters Option Button and select Memorize->Memorize Selected Item(s) Pose, obviously while the camera is selected. You can recall the position with Option Button->Restore->Restore Selected Item(s) Pose. Those options are also available through Edit->Object->Memorize (or Restore).
    But note that Memorise does not persist unless you save the camera, in a scene or a preset.
