About Collar Morphs
wqwwqw Posts: 11
Hello,
I have a problem. I want to make Morphs for a model, which is to stand the double collar of clothes. I tried many ways, including using the Soft Selection and FFD(BOX) of 3Dmax, but failed. I have not found an effective way even by combining Zbrush. What can I do about this?
  • Richard HaseltineRichard Haseltine Posts: 109,603
    So you want to smoothly raise the outer collar? It might help to define a custom workplane that lies along the top of the collar, then select each edge or vertex loop of the outer collar and y (or z in 3DS) translate it up. You'd then need to do some tidying up, but it would probably be a smoother result than trying to do it one operation.
