Cannot Install 32-Bit DAZ Studio 4.10, Pop-Up Won't Go Away
I have installed the 64-bit DAZ Studio 4.10 yesterday, and I did learn that you can also install the 32-bit version as well. But when I attempted to install it, I got a pop-up informing me that I must close the DAZ Studio 4.10 before installing. I did that, I pressed OK, and the pop-up just won't go away. To resolve the pop-up problem, I simply pressed CTRL-ALT-DELETE, selected Task Manager, and ended the task for DAZ Studio 32-bit installation, thus getting rid of the pop-up.
But the key focus of the question is, how am I supposed to install the 32-bit version of DAZ Studio if there is a pop-up that won't go away no matter how many times you click OK? What do I have to do in order to properly install the 32-bit version?
The reason why I want to install the 32-bit version is so I could use the lip-sync feature while creating animated videos in DAZ Studio. Unless there is a way to lip-sync to audio clips in the 64-bit version, but worst case scenario, I may have to buy an add-on to allow for lip-synching.
Did you try again, having made sure that there were no Daz processes running in Task Manager before launching DIM/the installer?
