Light spots in render
SassanikSassanik Posts: 340
Okay I am guessing this is a setting that needs to be adjusted? I am not sure what is the problem.
I have attached an image that I recently rendered and it has several "light" spots on the face. What is causing them? How do I fix them?
I am running Daz 4.5.1.56 Pro, with 3Delight and quality set at 4, otherwise standard default settings.
Thank you kindly!
Amy
  • JaderailJaderail Posts: 0
    Specular settings it looks like. Could be that or Reflection, both in the Surfaces Tab.
  • SassanikSassanik Posts: 340
    Thank you kindly! It does appear to have been the Specular settings. It seems the new V5 and M5 look freaky shiny on my computer!
    Amy
    500 x 546 - 23K
    Welcome. Happy it helped.
