[Solved] Decal appears reversed when applied
Hey folks,
finally figured out how to get an iray decal working in Daz (was using cycles in Blender previously). I realise this could be solved by reversing image in Photoshop, but was wondering if anyone knew what I am not doing to get the decal showing the correct way? Am sure it will be something rediculously simple!
I have played with X/Y/Z Projection Rotate with no luck. Any help would be really appreciated :)
Post edited by mike_from_nz on
Sometimes the UV map is simply backwards.
I'm also wondering if I had the axis' incorrect/reversed on import from Blender.
Solved, had the axis wrong when importing.
