Lights, Cameras, ACTION!!! Some fun with animation in D/S4.5
patience55patience55 Posts: 7,006
Spawned from an information request elsewhere in the forums are this set of images.
Desire was to film Genesis without a lot of wobble and to/froing.
Okay ... can post now, I'm loading the images into their slots ;-)
btw - read through all the images BEFORE following!
The 'camera test 3' that this all became is Here.
Post edited by patience55 on
    edited April 2013
    Continuing on ...
    799 x 391 - 55K
    1020 x 627 - 166K
    1104 x 589 - 120K
    1061 x 739 - 86K
    1325 x 863 - 151K
    edited April 2013
    Animating is fun although time consuming. One can render to still images or .avi files. Work can then be compiled in a movie making program and burned to disk for watching on one's very own television :-)
    1014 x 751 - 91K
    1056 x 580 - 43K
    788 x 637 - 52K
    1372 x 722 - 78K
    1027 x 492 - 58K
    edited April 2013
    You'll be glad to know I did skip a few images!
    1539 x 748 - 227K
    1023 x 759 - 137K
    1204 x 793 - 107K
    1396 x 820 - 156K
    786 x 803 - 58K
    edited April 2013
    The toon Dodo used in the tutorial is sold at Daz3d. It's a cute little fella :-)
    1163 x 789 - 136K
    1073 x 694 - 124K
    1587 x 849 - 187K
    1010 x 795 - 98K
    edited April 2013
    The pics are named with numbers so if they don't load correctly, hovering the mouse over them should show their numbered order.
    edit: I've loaded this set several times, don't know why but they just aren't lining up in the correct order.
    1404 x 626 - 75K
    1020 x 468 - 79K
    711 x 564 - 61K
    915 x 633 - 103K
    1410 x 776 - 127K
    edited April 2013
    Something similar to this could also be used for animating dog walking.
    1031 x 775 - 346K
    1255 x 759 - 325K
    1498 x 838 - 246K
    1073 x 606 - 69K
    Okay Jaderail, hope this helps.
  • JaderailJaderail Posts: 0
    Thank you Very much. I've been playing and I'm happy with the results so far.
    You're quite welcome. Thanks for the feedback.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,569
    I resorted to a single post per image because I could not get the order right on the forum no matter how I tried.
    I've found numbering them starting with some zeros helps. The post that has the pics mixed up jumped from a 02 series to 03. That might be what confused it. Putting names also confuses it. But then sometimes it seems to be sorting by size! Can't win 'em all ;-)
    edited April 2013
    This works for me. One size for all Images and Numbered. That works 99% of the time, the 1% I can not figure out.
    EDIT: My numbering Sys. 000, 001, and so on.
    Post edited by Jaderail on
    Wow. Nice tutorial Patience! :)
    Love the blue!
    I gotta tell ya though...
    When you get into Carrara a little teensy weensy bit more, You're going to kick yourself (hopefully metaphorically - only!) for putting yourself through so much agony! lol
    Wow... are D|S cameras really that much of a PITA? There MUST be an easier way! Don't be put out by me saying this. I'm being silly ol' me. I just never really animated in D|S further than creating custom aniBlocks. This short example is a simple no-brainer in Carrara. The backdrop was another story altogether. But I used the same camera to film the backdrop as I used to film the walk. In between I added lightning and rain in Project Dogwaffle: Howler.
    edited April 2013
    Think I'll try adding another "0" next time around but I suspect there will be always that 1% that doesn't co-operate.
    No cameras are not always this much work. This situation has something to do with Genesis.
    The camera flips over though on pass by shots from the side, would have to use at least 2 or 3 cameras to make a line walk from the side view.
    Apparently that has something to do with cameras hitting beziers [? sp].
    Haven't tested it yet to see if it works in D/S4.5 but there is a free script enabling one to render a scene in one pass using 2 or more cameras!
    My neighbour would love Rosie's hairspray! Her hair totally frizzes 'out' in a storm like that.
    Which reminds me, I made another little toy for people to play with ... I'll go upload that now.
    edit:
    http://www.sharecg.com/v/68505/view/21/DAZ-Studio/Coat007-Final-Update Has the mat for Genesis that was used in the tutorial if anybody wants it.
    http://www.sharecg.com/v/68801/view/11/Poser/Thing01
    Yep to the Genesis thing. Can use V4 M4 all day with a smooth dolly camera. Must be the Node order.
    Gleaned from the forums:
    Depth of Field QA
