Morph Loader Pro Eyelid Issue
Hello,
I have a problem with Morph Loader Pro!, I have a face morph wanting to merge it with body parameters to make full body morph,
so i'm saving/exporting the figure as obj. (mesh is base) then loading it back to G3F with Morph Loader Pro all is fine except the
eyelid I can't use Eye Closed because of it, It's like the Upper eyelid is displaced.
1st picture from Head morph only.
2nd picture after apply the new morph.
I hope if someone has the solution for this problem.
Thanks.
  • Does your morph move the eyelids? It may be that it includes the same in both of the base morphs, so combining them is doubling the effect.
