What to do when a part of outfit collides with another? **solved*
jenniferhughey
In the chosen outfit, when posed, some of the beads are hidden under the cloth. Is there a way to fix this?
Post edited by jenniferhughey on
Hello, I suggest you to look on my own topic about this kind of problem.
I fixed it by using: D-Form tool.
But more explanations in my post (wait I search it for you)... : https://www.daz3d.com/forums/discussion/197096/need-some-tips-on-smoothing-modifier
Is it a different item? If so, you can collide the beads with the shirt.
it's the same outfit, I can highlight the beads with the surface tool but not actually move them..
That was all pretty much over my head, but will search on the dformer tool and see if I can get the beads to lie on top of the outfit like they are supposed to..thanks!
Did you check for adjustment morphs? Morphs may be in the item's Shaping tab, or in the Parameters Tab under Actor.
Here's a Daz dformer tool tutorial (link should start video at the correct time): Posing, Shaping, and Deforming (Youtube)
And a longer one by VD GFX that I haven't watched yet: DAZ Studio - The D-Form Tool (Youtube)
No morphs for that section. I ended up moving her chest a tad and it fixed the issue. But I need to learn Dform. Thanks!!!
