Need help with GenX
galactica1981
I'm trying to use GenX to transfer a V4 morph to Genesis, and the first time the new morph wasn't any different. I think the problem is that I need to transfer the V4 body morphs as well but I don't know how. I haven't been able to find them like I have the M4 body morphs. Can anyone help me with this?
Post edited by galactica1981 on
Okay, I solved the above problem, but now I have another. I created this morph, and it looks good, but the mouth is crooked. As a result, if I change her expression, it looks awful. Is there any way to correct her mouth? If not, then I'm going to be really disappointed with this product.
Not the products fault.
can you give screenshots of the expression?
As you can see from the picture, her mouth is crooked, not straight. This causes problems whenever you try to change her expression. The V4 version of the morph does not have a crooked mouth like this.
I think I solved this. I redid the morph and removed all the non-zero values for the mouth area. Now it looks fine.
