Iray not rendering well
arcticfoxes_be
Iray rendering : frontal view face : right side does not render well. What's wrong ?
Thanks
arcticfoxes_be
Thanks
All I see is that there is a shadow from the hair across her face. It looks as if it needs to render longer too.
The right side of her face (looking at the image, not her right side) is shadowed by the hair. It receives less light and will need more samples to clear up the noise. Alternatively you can add more light (for example via a ghost light) and then adjust the brightness via tone mapping.
Ciao
TD
