Best African Tribal Jewellery
The Diigitals
Hey!
I'm looking for realistic, detailed African Tribal Jewellery. Prefereably for G3 although I've had some luck just hand placing it.
With an estimated 3000 tribes on the continent, you might want narrow down a region that you're interested in for jewelry.
Maasai
, Somali
, Zairian (DRC)
and Zulu
are just a few countries/regions/tribes with different styles.
There's a Massai Finery set over at Hivewire. It's for Dawn, but it ought to be usable on the Genesis series with a bit of scaling.
I am aware, it's just... I'm having trouble finding even one good, up to date set...
Ok let me take a look!
African Headwear contains some earrings and a headpiece along with the turban https://www.daz3d.com/african-headwear-for-genesis-3-female-s
Kente Clothing for V3 has some jewelry, but it would need to be parented (autofit mangles it) and likely resurfaced if you want to use it in Iray. https://www.daz3d.com/kente-clothing-for-v3
Beyond that, and the set that Jodel mentioned, there just isn't much.
Thank you! I have the turban and love it :)
I think the Masaai stuff at Hivewore is best so far, but no idea how to convert it from that to G3 :'(
Without doing an extraordinary amount of work, you really can't. You'll just have to parent it to either the neck or head, depending on whether it's a necklace or headpiece, scale to the appropriate size, if needed, and then use the XYZ sliders to refine its placement. And you'll need to use the XYZ sliders every time you change the pose.
I wonder what jewelry was used here?
https://www.daz3d.com/doctor-shadow-for-darius-6
https://www.daz3d.com/witch-doctor-for-genesis-2-male-s as well as the Shadow Man outfit itself
The items used are listed at the bottom of that product page.
How'd I miss that? Sneaking on DAZ site while at work, that's how. Thanks
