Faceshop 8/DS plugin not lining up
I finally got around to trying out the faceshop I bought at March Madness. Loaded it and the plugin works fine in DS (through the edit menu), face looks good up until I hit ok and it shows up in DS.
I have tried applying M5 morph at .5 and even tried it with the M5 morph loaded to Genesis first (yes I chose to output to M5) but no matter what I do the texture is loading unaligned. It does look like the morph from the photo applied correctly, however.
I have no clue where to go next.
It's like the whole texture needs moved down.
Post edited by scullygirl818_02147fecb6 on
  • Richard HaseltineRichard Haseltine Posts: 109,535
    You will probably need to use the Michael 4 UV Set, which you pick through the Surfaces pane.
  • TY3DArtTY3DArt Posts: 164
    I am pretty disappointed with the faceshop results also. Tried, V4,V5 and other characters, I have also purchased morph packages. It is okay, but no where close to what is advertised. FaceGen has a plugin for Daz. that works pretty good, I am just not up to spending another 100.00 right now, after dropping a ton of money on Daz Material.
