Help for DSON Importer for Poser
Alessandra CanassaAlessandra Canassa Posts: 26
Hello,
I'm having trouble with this installer in my Poser Pro 2012. for 64 bits
It is installed but not working ...
  • Richard HaseltineRichard Haseltine Posts: 109,018
    It means you need to have the files in a folder that isn't in program Files, essentially.
  • Alessandra CanassaAlessandra Canassa Posts: 26
    sorry I do not understand, can you explain better...how do I create this folder and where?
    Thank you
    The folder you install the content to needs to be outside the program Files (and program Files (x86)) folders - the default Poser content location is in your Public documents folder but if you didn't pick that you need to create a folder to install to, and you need to click the folder with a + and a little man in the top-right of the library pane and select the folder there to tell Poser to use it as an external library.
