ISO Long sleeved V-neck dress
zombietaggerung
in The Commons
Or a good suggestion for search terms. Ideally floor length, doesn't really matter what figure, since I'm going to try and dforce it. Free or pay. Similar to the attached images.
Thanks in advance.
The Nun ? https://www.daz3d.com/the-nun
Is for V4
Hmmm....maybe..... Do you know if the sleeves are part of the shrug bit or are they actually attached to the dress?
It appears to have short sleeves. At least the time or two I used it is is with short sleeves
Edited to add, just I pulled up my working Bryce files for the images I did using it and the sleeves are short, so the long sleeves must belong to the shrug.
Oh rats. Then, no that won't work. I need it to be all one piece. Thank you for the suggestion though.
Not floor lenght but would this work: https://www.daz3d.com/rianna-outfit-for-genesis-3-female-s
ETA to add alternate suggestion: Select a long sleeve dress you like and make an opacity cutout for the V neck
Lady of the Lake, has an under dress and an over dress The overdress has sleeves. https://www.daz3d.com/lady-of-the-lake-for-genesis
Ok, I'm an idiot. I actually found something: https://www.daz3d.com/daria-dress-outfit-for-genesis-3-female-s, which will work even though I don't really like the giant slits up the sides. Thank you for all the help!
Adding the v-neck with a transmap or the geometry editor would probably come closest to what you want. There were a number of long gownd in the PC collection if you are a member. Not too sure how they'll take dForce, but also check out overdresses. That first photo is something like a bathrobe, and dForce can be made to leave a belt or waist section alone and drape the rest.
