Edit a purchased animation?
no-mensch
Hi all,
is there a way to edit a preset animation tha I have purchased?
If I use a animation, there a a lot of little bugs, like hands in chest or head or something like that.
Can I edit these animation without editting every single keyframe in the timeline?
Thanks for your help :)
Maybe try to use the pose controls in the parameter pane like arms out, torso bend etc.
If your animation does not contain data for those you should be able to add some corrections without too much trouble!
bake to timeline
then edit with graphmate
https://www.daz3d.com/graphmate
I second that, keymate/graphmate are must haves if you want to do some serious animation.
It works with the posecontrol in parameters tab.
I will check graphmate to.
Thank you :)
