textures dont show up
http://www.daz3d.com/dynamic-kimono-expansion
and yes also got the kimono
Poser7 windows machine
The kimono shows up in the folders just fine but none of the textures. Ive looked and the folders are properly installed into the Poser folder yet they dont showup inside Poser, any ideas as to what I have done wrong and how to fix it?
Thx
Scott
According to the Product Page :
You should see the PP2 files in the 'Pose' folder inside Poser 7
The Materials for Poser are in MC6 format
You may need to apply these in the Material room yourself, I am not sure if these appear in the Library inside Poser.
Make sure that you have installed all of the necessary files
I poser 7 you will need to select the Kimono and then go to the material room to select the mats and apply them. AFAICR the materials library doesn't show up unless you are in the mat lab, although in P8 it does show, I am not sure if it changed in P7 or P8, as I jumped straight from P6 to P8
Thanks Pam :)
...thank you, my screen doesnt look like that, still trying to find out how to import a texture...
Thank you, the only textures I can find are in jpg format. Ive never had anything that the textures werent listed in the Poses tab in poser and you just click to apply...I guess i`m just sol here as it appears its installed correctly. Think this will be the last thing I buy for poser.
...thanks for the help but not going to waste time on it, this is really jacked, it created the folders and installed some but not everything, It also doesnt conform but I guess thats my bad for not seeing that, so its useless to me, Thx again.
There are two kinds of dynamic clothing sold in the store here, the one for DAZ Studio is made by Optitex, and will only work inside DAZ Studio. The other one is made for Poser, and it will only work inside Poser in the Cloth Room by using the 'clothify' option, and it is not conforming clothing, it merely drapes over the figure, and it does not have any rigging.
You can of course return any item that you bought in the last 30 days, but the clothing should drape OK inside Poser 7.
You do realise that if this is Poser dynamic you won't find it in the charcter library, but in the Prop Library, and you will need to run the drape in the cloth room, it will not conform
Also if you don't have the icons that I showed, then go to the Mat room and apply the MC 6 from there. Once you are in the Mat room you should find an option to go to the materials. (Not these are materials, and not textures as such)
...yes ma am I kinda figured :)
I`m so used to getting conforming clothing that I had not noticed it was just dynamic. ...and that I would need to go thru the cloth room. Sadly I have no clue how to pose it in the cloth room so will add that to my list of things to learn. I am learning Vue so learning clothroom will have to wait. Thanks for your help and sorry I wasted your time.
