Missing Data [FIXED]
XaatXuun
new HDD, so New Installs
downloaded the latest version of DS4 pro
been a couple days just playing with the basics that came with it and a couple other DL's
last night I started installing some other items, I have used and worked before
start up DS4.5 clicked on a saved model I created, and all I got was a block figure, so decided to start a new one, Genesis same thing
did it again to see what's missing
/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 5/FBMVictoria5.dsf
/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 5/FBMVictoria5Sprmdl.dsf
/data/DAZ 3D/Genesis/Base/Genesis.dsf
I reinstall, and still same thing
I recall this happened before, did something to fix, but cannot remember what I did to fix
Post edited by XaatXuun on
Make sure the place your content is installed (i.e. the folder containing the Data and Runtime folders) is listed in DS as both DS and Poser-format content.
the Genesis folder is empty :ahhh:
darn, I thought installing again would have fixed that, must be placing that data else where.
Thank you
, so all I need to find is where it's at, and place it in the right spot
just double checking,
So what I am missing, should it be in here ?
found it, don't know how it was moved to begin with.
Some how the 'Base' folder was moved out of the Genesis folder, just a simple move it back into the folder to fix it
what I really don't under stand is how re-installing DS4 didn't fix it :roll:
