Missing Data [FIXED]
XaatXuunXaatXuun Posts: 874
new HDD, so New Installs
downloaded the latest version of DS4 pro
been a couple days just playing with the basics that came with it and a couple other DL's
last night I started installing some other items, I have used and worked before
start up DS4.5 clicked on a saved model I created, and all I got was a block figure, so decided to start a new one, Genesis same thing
did it again to see what's missing
/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 5/FBMVictoria5.dsf
/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 5/FBMVictoria5Sprmdl.dsf
/data/DAZ 3D/Genesis/Base/Genesis.dsf
I reinstall, and still same thing
I recall this happened before, did something to fix, but cannot remember what I did to fix
Post edited by XaatXuun on
  • fixmypcmikefixmypcmike Posts: 19,686
    Make sure the place your content is installed (i.e. the folder containing the Data and Runtime folders) is listed in DS as both DS and Poser-format content.
  • XaatXuunXaatXuun Posts: 874
    the Genesis folder is empty :ahhh:
    darn, I thought installing again would have fixed that, must be placing that data else where.
    Thank you
    , so all I need to find is where it's at, and place it in the right spot
    just double checking,
    So what I am missing, should it be in here ?
    871 x 630 - 35K
    found it, don't know how it was moved to begin with.
    Some how the 'Base' folder was moved out of the Genesis folder, just a simple move it back into the folder to fix it
    what I really don't under stand is how re-installing DS4 didn't fix it :roll:
