SimonWM's Wet Body Iray Question
For anyone who owns the Wet Body Iray for Genesis 3 Males (https://www.daz3d.com/genesis-3-male-s-wet-body-iray), does it also work on Genesis 8 Males (with or without some tweaking)?
  • TooncesToonces Posts: 919
    Surprisingly, it works fine out of the box, perhaps because they share UVs.
    G8M on left, G3M on right.
    1920 x 1080 - 2M
  • pruggipruggi Posts: 151
    Thanks a lot Toonces, this was very helpful to see the comparison! Looks like I'll be grabbing it then :)
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    That makes two of us!  Thanks for posting the image @toonces.  Hopefully it is an easy to use product.
    It is. Literally just select the figure in your scene and double click on 'Rolling Water'.
  • HI, im having issues when genitals are applied. it turns grey.
    I've tried the solution here but because i'm relatively new to the scene of Daz im not getting a real grasp on this solution.
    Is there any way you can help me out?
    I'm using G8F with "rolling water" and the genetals are from renererotica called "golden palace"
