Missing instructions for UltraHD IRAY HDRI With DOF - Parks and Creation
in The Commons
For the life of me I can not figure out how to use this product. Does anyone know where to find instructions? Or want to clue me in? I guess if I was generally familiar with using hdri in daz it would help but I fooled with it when I first started and did not like the results so I've avoided it ever since then. The only think I've seen is the video that is on the sales page but the resolution on that is too low for me to blow it up to read the words in daz panels.
Have you watched the video on the product page? It looks as if they are mainly render presets, which will load the HDRI and apply settings to tweak the behaviour at render time.
I don't have this specific product, but if it is similar to other HDRI products in the store, you can start just by finding and double clicking the preset you want in the library. This will make changes in the render panel to the environment settings, and sometimes to the tone mapping settings. Then when you go to render you should see the results. If you want to make changes, it should be mainly in the render panel in the environment section, to do things like rotate the environment. I think MEC4D also had some videos about using HDRIs, which should apply here. I will see if I can find the thread.
Thanks. I sort of figured it out just by randomly clicking on things. It does seem a lot more realistic and easier to use than what I had before. I bought terradome 3 a while back and found it just too limiting. I assumed they would come out with some amazing morph sets for it but that has been limited too. Oh well. There is always photomanipulation in photoshop.
