Importing from Marvelous Design
R Golbraith
I made an outfit for Gen8 female in Marvelous Design. I made it a blue cotton fabric. I exported as an OBJ. I did not do textures because I don't know how yet. I opened DAZ, imported the OBJ and opened Gen8 female. It fits fine. But, it won't move with the model even though I parented it. So, the question is: how do I get this outfit to work with the model. Also, when you import something, where does it go and how do I put it where I want it?
You will need to use the transfer utility to add a simple skeleton rig to the item. Go to Edit->Object->Transfer Utility and select the Genesis 8 Female as Source and the outfit as the target.
